Discussion topic: WiFi keeps dropping on iPhone
This message was authored by: Fynnie
I had Sky installed in my new home yesterday, but my iPhone constantly drops off WiFi if I walk about 4 meters from where it is located (it completely does not work upstairs). My WiFi is showing as connected but then goes to 4G. I ran tests to check Sky Broadband when upstairs, & these are coming back as fine.
I have turned off Sky Assist & turned on/off my iPhone. My husband also has an iPhone, and he does not have this problem.
Why does this keep happening?
Re: WiFi keeps dropping on iPhone
@Fynnie
If your husband also has an iPhone and the issue doesnt occur on their phone then this suggests a problem with your device specifically. What model does your husband have vs what you have? What iOS version is installed on your husbands phone vs yours?
I am NOT a Sky Employee
Avatar for Fynnie
I can check tonight (after work), although we have used Sky broadband for years & not had this issue until we moved house... (when we moved on 20/3/25 both our iPhones were working with no issues, using Sky)...
Avatar for Fynnie
Update.. due to ongoing problems, a Sky engineer has installed three Sky max pods range extenders to my property, this seems to have resolved the issue.
