Discussion topic: WiFi keeps dropping in one room
Message posted on 24 Dec 2025 06:32 AM
WiFi keeps dropping out on the TV in my bedroom even though it's working fine on the same apps in all other rooms and on my iPhone 15 & iPad which is in the same room as the TV that keeps dropping out! So far it's taken me nearly 2 hours to watch 25 minutes of an episode from a series I'm currently trying to watch!!!
Message posted on 24 Dec 2025 07:48 AM
Re: WiFi keeps dropping in one room
@Ckdpx1 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
