Discussion topic: WiFi keeps dropping can’t. On coonect to sky Q box from sky mini box
This message was authored by: Tinkerbell8
WiFi keeps dropping a few times a day leaving all devices useless. Sky mini box keeps losing connection to sky box. Has to rec one t every time it's switched on. If it comes on 😡
Re: WiFi keeps dropping can’t. On coonect to sky Q box from sky mini box
@Tinkerbell8 There is just know way off knowing what you have or what you have/have not done with the system as you do not say, but the sky Q / mini rely on both of those devices to talk to each other over a wireless wifi signal....
If that is not good then they will always struggle to connect and remain connected to each other!
One off the major's is upgrading to the new sky Max hub and then sky Q issues start to appear!
