Discussion topic: Connection constantly dropping
Message posted on 27 Dec 2025 10:47 AM
Message posted on 27 Dec 2025 10:58 AM
Re: Connection constantly dropping
@Lorraineh75 If you use this sky help it will say what you can or cannot get to your home currently!
https://www.sky.com/broadband/full-fibre-broadband
or the BTW one below just use the address section and fill in ALL the required fields to see. If CF CityFibre is available just go to there site but sky may cover it on there's first!
Message posted on 27 Dec 2025 11:00 AM
@Lorraineh75 As you also do not say what you have then this may help you below if you have a potential bad connection!
Try running the line test here to see if any faults are found:
