Discussion topic: WiFi keeps disconnecting
Message posted on 03 Dec 2025 10:53 PM
Message posted on 04 Dec 2025 08:06 AM
Re: WiFi keeps disconnecting
@Martinrosbotham what hapoens to other devices when your phone disconnects? If they stay connected the issue coouldcsimply be your phone is. In an area of your home with poor WiFi - phones can switch to using mobile data automatiically if you dont want this to happen there is axsetting called something like WiFi assist which if you disable stops thst happening. You msy want to consider improving the WiFi in your home perhapa by buying Sky's WiFi Max paxkage that can supply up to 3 extenders in these are required.
Obviously if other devices have lost connection and the hub lights show it is not connected then tgst requires different steps see https://www.sky.com/help/articles/hub-lights-explained-start
