Discussion topic: WiFi keeps disconnecting
This message was authored by: Matt2212
Hi my WiFi keeps disconnecting and then reconnecting continuously. I don't know if it's due to the weather or a problem with sky but I need it sorted asap.
Re: WiFi keeps disconnecting
@Matt2212
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
