Discussion topic: WiFi keeps cutting off
Message posted on 14 Dec 2025 08:18 PM
Message posted on 14 Dec 2025 08:23 PM
Re: WiFi keeps cutting off
@Ki10
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
