Discussion topic: Drop outs
This message was authored by: Fairfield2
Drop outs
My WiFi keeps dropping out.
Re: Drop outs
@Fairfield2
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
