Discussion topic: WiFi it
This message was authored by: Beckham071
Message posted on 24 Feb 2026 06:34 AM
WiFi it
WiFi is not connected to devices mobile phone
Find out more
Message posted on 24 Feb 2026 07:13 AM
Re: WiFi it
@Beckham071 your post does not make much sense. If you mean your mobile phone will not connect to your Sky hub check you are entering the passcode correctly as it is easy to misread letters like I or O as numbers like 1 or 0 or vice versa.
If you are sure the code is correct tell the phone to forget the connection then power it down fully then restart it and add the Sky connection from scratch.
