Discussion topic: WiFi issues
This message was authored by: Alex339
WiFi issues
I have tried to ring up, it said there was a problem so I should check online but the app and online both say no issues, however I can connect devices to the router but I have no internet connection once connected.
Re: WiFi issues
@Alex339
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Avatar for Alex339
Re: WiFi issues
Hi, I have done all of this, however everything connects but has no access to the internet
