Discussion topic: No internet with sky
This message was authored by: Christy4
Sky router is working but not internet not working at all
Re: No internet with sky
@Christy4
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Avatar for Christy4
No internet
Broadband is ok but no internet at all .. I have to used my mobile data on all day.. please help me !!
I Bern try do everything's not working at all no internet!!
im so tired everything's .. I think I will call sky on  Monday !! Hope they sort it out and what to do next
Re: No internet
@Christy4
I have moved your new post into the thread you've already started. You need to answer the question asked by @Mark39
Avatar for Christy4
Yeah they fix come back my broadbands from yesterday .. that ok now .. thanks you for comments bye
