Discussion topic: WiFi issues
This message was authored by: Andrea148
WiFi issues
My sky broadband keeps dropping out or being weak. The checker says there is an issue but then when it runs tests the WiFi kicks back in and it says there aren't any issues when there are.
Re: WiFi issues
@Andrea148
For the wek signal try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
