Discussion topic: Anyone having trouble with ring camera wifi signal
This message was authored by: Chris5898
I have 4 ring devices and all good but 1 has a low rssi if 70. Sighned upto sky max no better so they sent an extender pod but still no improvement. The problem camera totally missing the pod and still connecting to the main hub furthest away from it rarther than the pod practically the other side of the wall 🤷. Also in my settings the 5gh is always off even when i toggle it on, go out come back and its off again?.
Re: Anyone having trouble with ring camera wifi signal
@Chris5898 Ring devices only use the 2.4GHz band to connect. The issue with  the pod is it is designed to radiate signal out away.from the wall socket it is plugged into not behind it. You may get better coverage if you plug it into on the far wall of the room.External walls are normally double thickness which inevitably going to reduce the signal which is why the best position for boosters is often near a window overlooking the camera.
Avatar for Chris5898
I cant get camera to even connect to the extender pod it's still by passing the pod and connecting with the router thats other side of house so extended pod unless
