Discussion topic: WiFi issues
This message was authored by: SophieJ21
WiFi issues
Yesterday afternoon and this morning, my WiFi keeps dropping out, this is my laptop and mobile phones, ive reset the hub multiple times, it works for a bit then happens again, used the checker which says its fine with good speeds. Its not. Please help!
Re: WiFi issues
@SophieJ21 Have you checked with the link below!
Try running the line test here to see if any faults are found:
