Discussion topic: WiFi issues
Message posted on 27 Dec 2025 09:35 AM
WiFi issues
I've just called your helpline and the test they ran highlighted an issue. The automated service sent me a link for self-help and this showed no issues. But we DO have problems. Can you help please
Message posted on 27 Dec 2025 10:22 AM
Re: WiFi issues
We are customers here only somtou are not talking to Sky.
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them and when asked any questions by the bot say nothing and remain on the line.
Message posted on 27 Dec 2025 03:36 PM
Re: WiFi issues
Thanks for the response. Why on earth would they send us to this route, with fellow customers? Seems like they are trying to shift responsibility for probloems away from Sky itself!
Message posted on 27 Dec 2025 03:56 PM
Re: WiFi issues
@DavidWilson2 Saves you hanging on the line to talk with CS, and hopes that you will go check the Help options if not done so already!
Tools in the toolbox so to say!
