Discussion topic: WiFi issues
Message posted on 16 Dec 2025 08:13 PM
WiFi issues
Good evening
we recently upgraded to better WiFi to solve the issue of unstable WiFi connection in my sons bedroom. We were told we could be sent a booster or extender free of charge if we were still experiencing issues. We are still experiencing the connection dropping regularly, therefore, please could I request the necessary equipment to improve the problem?
Many thanks
Becky
Message posted on 16 Dec 2025 08:19 PM
Re: WiFi issues
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 16 Dec 2025 08:20 PM
Re: WiFi issues
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
As you've closed your Community log in you'll need to contact Sky to arrange.
