Discussion topic: WiFi issues
Message posted on 01 Sep 2025 09:58 AM
WiFi issues
Message posted on 01 Sep 2025 10:02 AM
Re: WiFi issues
@Abicawse Are you seeing anything physical!
Message posted on 01 Sep 2025 10:05 AM
Re: WiFi issues
No all looks ok on router, lights all green. Online broadband check says everything is fine.
Message posted on 01 Sep 2025 10:16 AM
Re: WiFi issues
@Abicawse If you are able to from the link below take a look and see if you can post your stat's up, let the fields fill before you capture attach and post back, sample off the table very bottom is what you need to get!
