Discussion topic: WiFi issues
Message posted on 23 May 2025 02:37 PM
WiFi issues
I have recently had the cables to my telephone upgraded to fibre. Since that time I have had ongoing broadband and WiFi issues
Message posted on 23 May 2025 03:55 PM
Re: WiFi issues
@Katy60 And what would the issues be, your posting does not help apart from we know you have had a Fibre Install upgrade.
If you are looking for advice you need to part with some information. So post more detail if you wish.
Message posted on 23 May 2025 04:35 PM
Re: WiFi issues
My WiFi keeps crashing. However I have contacted sky and I will receive a new router. So hopefully all solved.
