Discussion topic: Broadband not working
Message posted on 23 May 2025 02:34 PM
My internet has stopped working I've turned the WiFi box off and back on green lights on WiFi and power but no light at all on Internet
Message posted on 23 May 2025 02:45 PM
Re: Broadband not working
@Lizzie44
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 23 May 2025 02:55 PM
Thank you. Just got off the phone with sky and they spoke to BT who have informed them there is a fault their end and should be fixed in next 24 hours so just have to wait
Message posted on 23 May 2025 02:58 PM
Not BT, it will have been Openreach. BT are a direct competitor to Sky.
Message posted on 23 May 2025 04:24 PM
Yes same difference, BT owns open reach. I'm in a new build and had to go with BT / open reach when moved in then moved to sky. The infrastructure is openreach but I use sky services now
