Discussion topic: WiFi issues
This message was authored by: GemmaGibson07
WiFi issues
Good evening, our TV keeps buffering while watching programmes online, IE Netflix. Just buffers and then says unable to
connect, I've checked the speeds and everything seems okay, but still happens intermittently.
Re: WiFi issues
@GemmaGibson07 Is it only netflix that has the issue?
Avatar for GemmaGibson07
Re: WiFi issues
Hello unfortunately not, it's anything that uses the internet
Re: WiFi issues
@GemmaGibson07
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
