Discussion topic: Router problems
Message posted on 04 May 2025 10:29 AM
Router problems
The WiFi keeps dropping out but the router says it's okay. We unplug from power and then reconnect to reset it but it still keeps doing it. We have had this router for over six years.
Message posted on 04 May 2025 12:11 PM
Re: Router problems
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 05 May 2025 10:23 PM
Re: Router problems
Thank you for the help! I've tried that tests and both say they're fine so I'll give customer services a ring tomorrow. Thanks again for the advice. Much appreciated.
