Discussion topic: WiFi issues
Message posted on 10 Apr 2024 10:47 AM
WiFi issues
Message posted on 10 Apr 2024 11:00 AM
Re: WiFi issues
@trevjnk Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 10 Apr 2024 11:08 AM
Re: WiFi issues
I appear to be having a similar issue, broadband ordinarily at 25-30Mbps but collapses to less than 1Mbps. These collapses rectify but can take 5-30mins and occur 5-10 times a day. This issue was reported to Sky a few weeks ago who responded 'all fixed' with no other detail. Nothing has changed in my set up or vicinity of the router.
