Discussion topic: WiFi issues slowness
This message was authored by: TeganIndia
For the last couple of weeks our wifi connection has suddenly dropped in our home, when using laptops and tv everything has started lagging and not loading.
we're not sure why this has happened as our box says everything is fine and we're not using any more details than normal, we're wondering if it's because anyone in our building may now be using sky? (Were one flat in a building of six flats?) We just really need this fixed and it's becoming a issue, thanks!
This message was authored by: Me134
Re: WiFi issues slowness
It won't have anything to do with your neighbours with the possible exception of if you shared your WiFi details and they've stolen all of your bandwidth 😉 (for clarity, this is just a bit of humour as this place sometimes needs it).
The following is nicked off @caesarome so give him the like if needed 😉
Try running this line test to see if it finds any faults:
Not a Sky employee
Sky FTTP 500Mb to Max Hub
