Discussion topic: WiFi issues connection slow or not connecting
This message was authored by: RachelReid05
Im having issues with WiFi upstairs in my house and in 3 downstairs rooms. 2 of the downstairs rooms are at the back of the house and 1 is at the front across from the living room and in the hall between the living room and front bedroom there is a pod) All of upstairs is effected and this has been ongoing.
Re: WiFi issues connection slow or not connecting
@RachelReid05 wifi signal strength depends on the layout and how your home is built. Older properties with solid walls often have issues.
As a first step check your hub is in the best podition which is off the floor on a surface out in the open if it is then you are going to need boosters which Sky can provide if you buy their WiFi Max package.
