Discussion topic: WiFi issue
This message was authored by: Katie355
WiFi issue
Hi,
My WiFi has suddenly stopped working properly and won't connect to devices and saying password is wrong when the password isn't wrong.
it also keeps dropping off and back on.
Re: WiFi issue
@Katie355
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
