Discussion topic: Internet not working
This message was authored by: Ryan227
Hi my WiFi had stopped working, I’ve tired all the steps. The internet will not come on the router so I have no internet.
Re: Internet not working
@Ryan227
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
