Discussion topic: WiFi issue
This message was authored by: SylwiaNiecieck
WiFi issue
Hello there, There appears to be an issue with my WiFi since yesterday. I’ve already tried resetting the router, but the problem keeps reoccurring. Could you please check what might be causing this and how it can be fixed? Thank you. Kind regards, Sylwia
Re: WiFi issue
@SylwiaNiecieck
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
HAPPY NEW YEAR
