Discussion topic: We have no wifi at home
Message posted on 18 Nov 2025 05:17 PM
We have had no wifi since about 11.30
Message posted on 18 Nov 2025 05:48 PM
Re: We have no wifi at home
@JaneBurrow
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
