Discussion topic: WiFi issue
This message was authored by: Aishachohan
WiFi issue
My wifi isn't working
Re: WiFi issue
@Aishachohan
For a broadband issue use this link to check to see if there are any issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
