Discussion topic: WiFi issue
Message posted on 25 Sep 2025 04:27 PM
WiFi issue
Hi,
my home hub is showing no light for the internet and an orange light for voice. No devices can connect. I've restarted the home hub twice with the same result.
pls advise or check your end.
thanks,
Marc
Message posted on 25 Sep 2025 04:30 PM
Re: WiFi issue
@Marc68
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer led discussion forum where we try to help other Sky customers.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Message posted on 26 Sep 2025 02:27 PM
Re: WiFi issue
Thanks Daniel 👍
