Discussion topic: Internet not working
This message was authored by: Miss+mcguckin
Re: Internet not working
@Miss+mcguckin
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
