Discussion topic: WiFi issue
This message was authored by: Cheyn
WiFi issue
Good day, my WiFi has no connection, however when I run a test it says everything is fine, however the WiFi light on my router is showing orange and no connection. Please advise what the issue is?
Re: WiFi issue
@Cheyn
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If you’re still having problems you may need to call Sky to report it. Dial 150 free from your Sky Talk landline (if it’s still working) although the lines are closed at present due to technical issues.
HAPPY NEW YEAR
