Discussion topic: Orange light no wifi
This message was authored by: Cara85
WiFi not working. Followed all the steps and still middle light orange
Re: Orange light no wifi
@Cara85
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
If you’re still having problems you may need to call Sky to report it. Dial 150 free from your Sky Talk landline (if it’s still working) although due to technical issues the lines are closed at present.
