Discussion topic: WiFi issue
Message posted on 18 Aug 2024 03:26 AM
WiFi issue
Message posted on 18 Aug 2024 06:17 AM
Re: WiFi issue
@Br11964 You need to consider what lies in the path between the location of the hub and the area with the dead spot. Wifi signals are carried ultra high frequency microwaves so are blocked by even a thin layer of metal. They are attenuatedcwhen passing through solid objects like walls.furniturecand even people.. This why it is advised to place the hub out innthe open on a surface above obvious obstructions like radiators.
A useful tool is an app called WiFi sweetspots that you can download ontona phone and will tell you in near realtime the speed of the wifi connection from the router as you move round the house. .
