Discussion topic: WiFi issue - Glasgow
Message posted on 22 Aug 2025 11:22 AM
We're having a problem with our WiFi - everything looks ok ( router showing all green lights ) but no WiFi - we're in Glasgow ( G42)
Message posted on 22 Aug 2025 11:25 AM
Re: WiFi issue - Glasgow
@Judep1704
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 22 Aug 2025 11:35 AM
Hi - thanks for this - have tried everything suggested so will need to call Sky .
