Discussion topic: WiFi isn’t working
This message was authored by: Victoriamotley
WiFi isn’t working
Got two red lights in the box and no WiFi is working
Re: WiFi isn’t working
@Victoriamotley
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
