Discussion topic: WiFi isn't working
This message was authored by: Tricia+brokenshir
WiFi isn't working
Turned off and back on but still np connection on TV or anywhere else
Re: WiFi isn't working
@Tricia+brokenshir
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
