Discussion topic: Internet is not working
This message was authored by: KimmyB88
Was watching Netflix and it cut off then looked at the router the second and fourth light was orange so I unplugged it and turned ir back on and it's still not working
Re: Internet is not working
@KimmyB88
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
