Discussion topic: WiFi isn’t working
Message posted on 15 Apr 2025 08:16 PM
WiFi isn’t working
My router is showing as Green for internet but there is no wifi when I connect my devices, when it does connect it will drop out after 5-10 minutes and then stay off despite several resets etc.
Funnily enough it has only started happening since my bill increased at the start of April!
Message posted on 15 Apr 2025 08:18 PM
Re: WiFi isn’t working
Sorry it is showing as orange for internet, green for power and wifi
Message posted on 15 Apr 2025 08:25 PM - last edited: 15 Apr 2025 08:25 PM
@Bhughes1 It's unlikely a price increase would cause this issue, to think it would is ridiculous.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 15 Apr 2025 08:58 PM
That comment was tongue in cheek.
Thank you for your response, I have tried these but still have no luck. The internet will come back on briefly and then cut off again, this has been happening for over a week now. It seems to occur after I begin to use the internet to watch Netflix or Sky Go.
