Discussion topic: WiFi isn’t working
Message posted on 05 Feb 2025 08:04 AM
WiFi isn’t working
My internet has been up and down since yesterday
Message posted on 05 Feb 2025 08:24 AM
Re: WiFi isn’t working
@Dee391
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
