Discussion topic: WiFi isn’t working
This message was authored by: Mahitha
WiFi isn’t working
WiFi isn't working since 11:30AM. Tried restarting and followed all the instructions given by virtual assistant,but still no luck.
internallt signal flashing orange-checked for connection in the area it says all good.Not sure what the problem is.
Re: WiFi isn’t working
@Mahitha
Try running this line test:
Avatar for Mahitha
Level 0 icon
Thank you for your response.
Tried all that-it shows everything is okay with green color.Not sure what needs be done!
