Discussion topic: Internet Speed and Wifi Connection
Message posted on 18 Nov 2024 10:54 AM
I am really unhappy with the speed and wifi connectivity recently.
I have gone onto fast.com and getting speeds of 34mbs.
My wifi keeps dropping out and I cannot even have a call on Teams.
Message posted on 18 Nov 2024 01:30 PM
Re: Internet Speed and Wifi Connection
@christiandalby 34Mb/s is ample downstream speed for Teams but the issue could be the upstream speed or an unstable signal. However given WiFi speed and stability are affected by the layout of your home, how it is built and the level of interference its impossible to know why you have an issue.
Using WiFi for working from home is not ideal Ethernet cables are far more reliable. If you have to use WiFi and work some distance from the hub then you are likely to need some form of extender.
