Discussion topic: WiFi isn't working
Message posted on 03 Sep 2024 11:11 AM
WiFi isn't working
Message posted on 03 Sep 2024 11:16 AM
Re: WiFi isn't working
I'm having the same problem. Done the checks says all ok. But on tv my connection to internet keeps dropping out?
Message posted on 03 Sep 2024 11:17 AM
Message posted on 03 Sep 2024 11:20 AM
@Nicola732& @Vaishali1 & @Mick24 is this the service checker that you are using to check your broadband issue is or are you also running the broadband test after the service checker completes?
Message posted on 03 Sep 2024 11:23 AM
I'm unsure what a service checker is? And I've followed the instructions on here as in a test and saying ok. Sorry but I'm a bit naive on stuff like this.
Message posted on 03 Sep 2024 11:25 AM
@Mick24 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 03 Sep 2024 11:28 AM
I've done everything and says all ok? Not giving me an option to get a engineer?
Message posted on 03 Sep 2024 11:29 AM
I have done all of all the testing. It comes back fine with no faults after trying constantly.but there's clearly something not working well, Router internet light goes green. After 5-10 mins starts flashing amber and the cycle repeats and tries to connect and then does. It means I cannot get on work calls or anything. I am happy to post a video of the router or send to someone specific if this helps.
Message posted on 03 Sep 2024 11:30 AM
Is your router internet light also going amber after some time and then resolving back to green?
@Mick24 What lights are not showing on the router just now? Are any amber or have no light at all?
Message posted on 03 Sep 2024 11:32 AM
@Vaishali1 Which area of the country are you in. Hemel Hempstead is having a major outage just now.
All the lights are green. But intermittently my internet drops out for a split second. Was doing this the other week but seemed to right itself
Message posted on 03 Sep 2024 11:35 AM
@Mick24 Do you have a black or white router from Sky?
Message posted on 03 Sep 2024 11:36 AM
I'm having the same issue, all lights are green, all service checkers say everything is fine, yet I have no connections anywhere, currently working with my 4G. That's been since 4am, and I'm in Powys
No it's just black?
