Discussion topic: WiFi isn’t functioning properly and getting worse
Message posted on 13 Jul 2025 10:47 PM
WiFi is not functioning properly and is gradually getting worse and isn't fit for purpose. Tried all the options turning the box off and reconnecting but after half an hour cuts out
Message posted on 14 Jul 2025 03:26 AM
Re: WiFi isn’t functioning properly and getting worse
@Andrew305
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
