Discussion topic: WiFi is not working
This message was authored by: Nazir12
WiFi is not working
Hi my WiFi is not working
Re: WiFi is not working
@Nazir12
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn't working check this for problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
