Discussion topic: WiFi is not working at all. Please help.
This message was authored by: SunR
WiFi is not working at all. I need it up as I work from home.
Re: WiFi is not working at all. Please help.
@SunR Run the connection test in the My Sky app using a mobile connection as that will tell you if tgere is a known issue with your line. If it doesnt give Sky a call their lines should be opening now.
However do note if the fault is with your line Openreach will probably not be able to get an engineer to check it for a couple of working days which is the SLA for domestic connections the fact you choose use it for work does not increase the priority.
