Discussion topic: WiFi is down
This message was authored by: Jade63
WiFi is down
The LOS light is red on the white broadband box
Re: WiFi is down
@Jade63 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
