Discussion topic: WiFi is bad
This message was authored by: Kirsty1236
WiFi is bad
We are having issues with wifi very intermittent
Re: WiFi is bad
@Kirsty1236
Wi-Fi and broadband are different.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
