Discussion topic: WiFi in the loft
This message was authored by: D_F
WiFi in the loft
My WiFi is always disrupted at creations times and devices go off especially it reaching to the loft . We need an engineer to looks at this
Re: WiFi in the loft
Hi @D_F
Could you please clarify what you mean by 'creations times'?
As for devices going off when you reach your loft, this is likely just a range issue. If you have a converted loft its more than likely you need a booster to cover it. Provided its a proper conversion thats been boarded with a proper staircase then it should be covered under the WiFi guarantee which can be found here https://www.sky.com/help/articles/wifi-guarantee
I am NOT a Sky Employee
