Discussion topic: WiFi help
This message was authored by: Tammy_86
WiFi help
My WiFi isn't as fast as I got told it would be .
Re: WiFi help
@Tammy_86  What does the service check tell you are getting to the router? If you are getting the speed you are supposed to, the speed within the property can change depending if the devices are connected via a wired connection or a Wi-Fi connected device.
Avatar for Tammy_86
Re: WiFi help
It's telling me the speed is lower than they promised.
Re: WiFi help
@Tammy_86  Does it give you any information on how fix this lower speed?
Avatar for Tammy_86
Re: WiFi help
No it's just saying phone to make a claim.
Re: WiFi help
@Tammy_86  Give Sky a call to see what they and can be done to fix the speed loss.
